Oil Pan Drain Plug......
broncoitis
Drips, Leaks, whatever! For some reason mine continues to drip. Have a new gasket on there and she still drips. I don't wanna tighten it too much but this is getting a little frustrating. Funny thing is that it doesn't do it all the time it seems.
Any suggestions or anyone else with a similar problem. ;D
bmc69
I've seen a few with a hairline crack develop at the outer 'edge' of the circular area on the pan metal where the bolt and washer seat. Usually quite a small crack and well disguised by the edge of the work-hardened area and slight indentation that develop over many years of oil changes.
But if there is definitely no crack and you are using a fresh nylon washer to seal it...
broncoitis
broncoitis
Hmmmm! I will have to take a closer look. %)
GubNi
Northeast TN
Autozone has one that is a universal rubber style for stripped oil pans that works really good.
TDubya
Fortuna, CA
Try picking up a new plug from the parts store. I thought that I had stripped the threads on the pan after overtightening the plug to stop a drip. I pulled the plug and was pleasantly surprised to find the threads galled on the plug and not the pan. Threw on a new plug, snugged it up, and no more drip!
broncoitis
broncoitis
Thanks guys! I am gonna get a new plug! Hopefully that does the trick and cures the drips on this pan.
What about the type of washer to use anybody have a preference? I got the pack of 4 nylon washers 1/2" they have little ribs on them. Any good or garbage? :eek:
