    Discuss it more here:
AZ Passenger side AC compressor bracket wanted
hahnn6
Newbie
City: Gilbert
Looking for a passenger side AC bracket for my Sanden compressor (vintage air) please let me know if you have something that'll work with it. I have a V-belt setup on the stock 302 motor.
THEBONE
Are looking for the bracket for the old school dealer added ac? If so I may be able to help.
H
hahnn6
Newbie
I think I'll be able to find an adapter to the sanden so yes that would be great if you had one!
Slowleak
Georgia
Those York to Sanden adapters are easy to find, even on Amazon. I have one on mine. Spacing can be tricky to prevent the fan blade from hitting the compressor clutch but that’s going to happen with any bracket.
H
hahnn6
Newbie
[/URL]
Awesome thank you, would that dealer add-on ac compressor bracket change the location of my alternator in the stock passenger side position or does it work in conjunction with that?
Slowleak
Georgia
It works with it. Pull off the alternator, add the bracket, install the alternator. It’s kinda sandwiched in there. You may need longer bolts….. not sure about that.
H
hahnn6
Newbie
is it just one bracket on the front of the head or is there a second bracket that goes to the exhaust manifold side of the motor
Slowleak
Georgia
It’s just one bracket like pictured below. The adapter bolts to the flat plate on top where the York is bolted, and has ears sticking up for the sanden compressor. The alternator fits in the opening in the bracket below the compressor. Idler pulley for the belt sits behind your upper radiator hose. With the York there was a steel brace from the top of the compressor to the manifold.
H
hahnn6
Newbie
Do you have an idler pully for your sanden or did you run it without? Thank you for the pics and description, very helpful!
Slowleak
Georgia
Yes. You will need the idler, it’s the only was to adjust belt tension. They are also easy to find and bearings can be replaced in them as well.
H
hahnn6
Newbie
And does the sanden run off the same two groove water pump pulley and same track as alternator?
Slowleak
Georgia
Nope. I am assuming you have power steering? You will need a three groove crankshaft pulley. Alternator runs in the rear groove along with waterpump, then power steering in the center along with the waterpump pulley (front groove of it) and the compressor is by itself in the front groove.
H
hahnn6
Newbie
Do you happen to have a recommendation for that crankshaft pulley? It's a 69, original 302, I believe it's a 4-bolt
Slowleak
Georgia
Do you happen to have a recommendation for that crankshaft pulley? It's a 69, original 302, can't remember if it's the 3 or 4 bolt
Can’t help much there. Mine have all had a 3 groove when I bought them. If someone doesn’t chime in, you might check with CVF Racing. I have their waterpump pulley and they sell good stuff.
H
hahnn6
Newbie
Great, I will... thank you! And it's a 3-bolt pulley I just found old pictures (I'm at work currently not around the bronco)
H
hahnn6
Newbie
Thebone is hooking me up with an AC bracket! Very excited for that, it doesn't have the idler assembly on it, can you point me in the best direction to source that setup? Thank you
Slowleak
Georgia
This is what you want.
One of these:
And one of these:
A couple of bolts to hold it together and you are good to go. I’m sure you can find both of those parts elsewhere but those are the correct size.
This bolt might do it for the pulley:
