DonsBolt
Yo my Bronco Brothers and Sisters
I just want to make sure mo one else screws up like me when doing the NV3550 trans swap.
When I did the swap this past November I went over to a friends place who own a Jeep and 4x4 shop. When we went to put the pilot bushing, or imput shaft bushing in, or whatever it is called. My friend just pressed it in flush to the flywheel, I can't really blame him, and I am not mad at him, since no one is perfect. I guess on the Jeeps the bushing is flush with the flywheel when pressed in all the way. However on a Ford the bearing is actually recessed about 1/8 of a inch into the flywheel.
Well about a week ago my Bronco started making a bad sound when you pushed the clutch in. I though maybee I just got a bad throw out bearring, so I ordered a new one, and just to be safe I called avanced addaptors and ordered a new Pilot bearing.
So today I went back to my friends place and we pulled the trans back out, and sure enough the Pilot bearing was messed up. After we removed it, I measured the hole it goes into, and it was clear the hole is deeper than the bearing. This time I pressed the bearing in myself, and sure enough the new bearing sits in close to 1/4 further than the old one.
Ondce everything was put back together, and I drove home, I now notice that it shifts better, makes no noises, and maybee has a little more power.
So just a word of caution if you are about to install a NV3550, make sure the Pilot bearing is seated all the way in. Lucky for me I didn't do any damage to the new transmision or clutch, but I was lucky nothing else happened.
So all is good now, but want to make sure no one else screws up like I did.
So be well my Bronco Bros
