Speedometer Bounce Issue
Fewellrb
Nashville
My speedometer bounces around so much it is unusable. If I’m going 30 it will bounce between 5 and 50 every time I touch the gas. Is this normal or is there a fix?
Slowleak
Georgia
First thing to try is lubing the cable. I use this stuff..... found it at Ace Hardware.
disconnect the cable from the speedo. Pull the flex shaft out of the housing. Clean it good to remove any dried oils, lube it, and reinstall.
Hotrodjohn
more than likely the cable, Id try that first. If that cable is getting some bind it will cause the needle to bounce. Second would be the speedo head itself.
B RON CO
Statesville, NC
Hi, X2. I would disconnect both ends and spay WD 40 from the speedometer head down, and give the cable a nice cleaning. If the inner cable still binds try a new cable. Good luck
blubuckaroo
Grease Monkey
Ridgefield WA
Yes, service the cable, but don't over tighten the nut at the speedo head.
It's designed to be only hand tight.
The hex nut makes you think you should put a wrench on it, but don't do it! That can put things in a bind.
Oh, and I just noticed this is your first post.
Welcome aboard Fewellrb!
g-71
I had to do the clean, relube process twice to get mine working.
