Nothing Special
- Nov 25, 2016
- 805
Thanks for the input. If I had a stroker of 408 CID and made 500ft/lbs of torque with a short duration/fast-ramp camshaft I would start making torque at 850-rpm. Would that be 80% of my maimum torque? Maybe that would be 400-ft/lbs of torque. Maybe that would get my Bronco started on Grand Teton hills. How many MPH should I be turning when the the torque is engaged at 850 rpm?
You're not asking the right questions so it's hard to give you answers. You do not want an engine that makes 80% of it's torque at 850 rpm. It would be like a tractor engine, good at pulling but too heavy and slow to be useful in a street-driven vehicle or a trail vehicle.
And what do you mean by "when the torque is engaged"? I've been assuming you are talking about engaging the clutch with the engine turning 850 (or previously 1000) rpm. But you typically are engaging the clutch in order to start moving, so the vehicle speed is 0 mph and asking "how many MPH should I be turning" is meaningless.
Now as for the frame. When I am done building I want to strip the frame down and take it to a black smith for heat treating and maybe cryo-treating. Maybe I can beef it up/thickening it.
I am open for changing the gear ratios of the NV4500. Is 7:1 low enough for the granny gear? What is the optimium gear ratio for use as an Alpine gear?
You haven't told us why you need such a torque-monster motor. Your only stated goal has been to start on steep hills in the Tetons. The stock 3 speed manual transmission with a stock engine will do that. A transmission with a granny low first gear will do it even easier, but again, you don't need a monster engine to do it.
You do need to be proficient at using a clutch however. And as noted above, some people are better served by an automatic transmission.
And changing gear ratios in a transmission is a huge job. Very, very few people would be capable of doing that. And there's no one answer to "what's the optimum gear ratio." It will depend on axle ratio, tire size, engine power curve and your own expectations, which are likely different from mine. Personally I think the 5.6:1 first gear of an NV4500 would be pretty good for most mountain driving.
