Bronchole
Starting my 4R70W project, what should I know?
I am going to start tearing in to my 4R70W this weekend so I thought I’d ask if there is anything I need to know.
Here is what I am starting with
- 1967 Bronco
- Currently it has a wore out 5.0L in it but I will be replacing it with a mildly built 351W (400HP, 400 ftbl 1500 thru 5000 RPM power range) in the next month or so.
- 4.11:1 gears that will be replaced with either 4.88:1 or 5.13:1 gears sometime in the next year.
- Holley throttle body injection (4DI) wil eventually be replaced with a Ford fuel injection system, but at least after te 351W is broke in, probably next winter.
- 35” tires
- Dana 20 with Tera-Low gears (3.15:1 low range) and Wild Horses HD output shaft.
- 30000 GVWR trans cooler and in radiator cooler plumed after the external cooler.
- Autometer mechanical transmission gauge.
- This rig did have a C4 in it previously.
Here is what I got:
- 4R70W from a 2000 (mfg 11/99) Explorer 2WD. This has the hardened intermediate shaft and the mechanical diode upgrade from the factory.
- Torque converter from a 1997 Mountaineer that had a 4R70W
- Dust plate from the same Mountaineer
- Advanced Adaptors AOD to D20 adaptor kit
- Advanced Adaptors AOD to 4R70W shaft adaptor kit
- Baumannator TCS system
- Bauman valve body
- 4R70W master rebuild kit
- Ford Racing 28oz imbalance AOD flex plate
- Flex plate from the Mountaineer with a 50oz imbalance
- Full rebuild manual, video and TSB’s
The process:
- Remove the broken C4.
- 4R70W is on a clean bench .
- Tear down the 4R70W, do a full rebuild to it and as I assemble it install the Advanced adaptors stuff and the Bauman valve body.
- Assemble the Dana 20 on to it (I rebuilt it a few months ago) .
- fill the Torque converter up to the snout.
- Throw the assembly in to the Bronco with the mountaineer flex plate and tin.
- Put in X quarts of trans fluid to start.
- Install starter.
- Fabricate some new frame mounts for the original Dana 20 cross member.
- Take the measurements for modifying the driveshafts and send them out to be modified.
- Modify the exhaust to fit the new longer transmission assembly.
- Modify the stock 1973 automatic column shift linkage to work the new trans assembly
- Rewire starter solenoid for new starter.
- Install the Baumannator TCS.
- Check fluid levels and see if it can take some more.
- Start the motor, immediately check trans fluid level, add as necessary.
- Cycle the transmission thru the gears, add fluid as necessary.
- Install the reworked drive shafts.
- Take for a test drive!
So here is your chance to tell me what is wrong with my plan or to give me any little nuggets of info that you think I may need.
Dan
- 1967 Bronco
- 35” tires
Here is what I got:
- Bauman valve body
The process:
- Install starter.
Dan
