Hello Bronco Gods.
Not sure why the pictures are not straight, or why they tilted, sorry.
After driving my bronco over 7 years with the same shocks setup, time has come to replace them.
i am running 35 inch tires with extended radius arms, 11 leaf springs, dual rancho 9000 adjustables in the front and single explorer shock in the rear. it has a body lift and 3.5 inch lift, i didnt built the shocks setup, I only did the suspension setup which was radius arms and the 11 leaf springs.
like to address that this shock setup was never changed when i added extended radius arms, because i didnt have enough in my budget to replace shocks. i had dual shocks running on factory regular shorter radius arms.
The dual front shocks are 17"and 16" collapsed, one is an inch higher then the other. The single rear shock is 15" collapsed. The shocks are all extended out 6.5 inches when bronco on level ground, as seen in pictures.
i ride the bronco on daily basis and i do light offroading every few weeks.
i want to put new sets of shocks and looking at the bilsteins or fox 2.0, i dont want to go with ranchos for now.
What do you guys have for a setup? could i see some new pictures?
i understand that the shocks that i have chosen are pretty expensive but i am willing to spend that extra to have a better ride and handling.
my 1st main question,
Do i need to put dual shocks in the front or can i get away with just single shock? remember , the shocks i have are pretty old by nowand could be beat up. i dont really see much of a difference in the adjustable shocks when putting in any position, either loose or tight, they are acting the same.
2nd question,
Do i have to get the same size of shocks or do i have the option of getting an inch longer shocks? as i mentioned the shocks in the rear 15" collapsed, will
16" shocks be better or worse?
3rd question,
Do i need to get adjustable shocks again? i have noticed some guys dont have adjustables, they run a normal shock.
i have seen the new shocks from bilsteins or fox that do come with a reservoir, with adjustables, correct? i am gearing more towards that.
4th question,
Do you guys think i am making a big mistake and just should go back to ranchos and forget these new bilsteins or fox shocks that do come with reservoir and are adjustables? should i just get the normal bilstein 5125 or go with 7100 or how about the fox 2.0's factory series?
I really appreciate all the help.
Best Regards
