Yes, one of them at least. I also like using a fan only, such as the #5049 or #5051 and creating my own deeper shroud.
Unfortunately deeper mounting and shrouding is not always possible in a Bronco (much of the time!) so the #5044 was a solution to that problem. It's still deeper than other aftermarket shrouds (to promote a little more pulling through the entire radiator core) but still fits within the narrow Bronco space. (measure yours to make sure though, as things may have been changed without your knowledge).
This goes back to the Explorer setup though. I hear you on the old school look, but sometimes gaining that extra 3/4" of space in front of the water pump snout trumps all other factors!
I think V-belts are cool, but serpentine with wide belt in a compact package is the winner winner chicken dinner of almost every Bronco modification.
So at least keep it (and it's expense and trouble) in mind as you're living with your Bronco.
And definitely make sure everything else is optimized so you're not spending money AND still fighting an overheating issue.
Remember that a good mechanical fan setup is almost always stronger at pulling air than a good electric setup (except at low rpm of course). Which means that while electric has some distinct advantages over mechanical, it won't overcome a problem engine cooling scenario. Seen it many times in person and here on the forums.
Not really trying to talk you out of electric (like it might sound) because like I said I'm a big fan
I'm just making sure you've seen all the pros and cons and have already been down your own road of discovery for why your Bronco is running hot.
Have fun!
