I have a set of the Big bronco front discs on my dana 44, with hydroboost. I also have the cage long arms and good C-bushings etc. I recently noticed that if I stab the brakes real hard in a panic stop, the bronco tries to shoot me left into oncoming traffic So I checked the brakes and both sides are in good shape pad wise and both caliper cups seem to retract and operate normally. I did notice that the passenger side when I grab it, its really stiff and hard to wiggle. The drivers side is fairly free and I can wiggle it a whole lot more? I decided to remove the calipers and check everything out and then used anti seize on where the caliper mounts the bracket hoping it might free it up, and it worked but not enough to correct the braking issue. It almost seems like maybe I got two different sized calipers on the same bracket?
Anyone care to take a stab at this.
