- May 11, 2013
- 1,760
Howdy. ran into some interference. new doors with removable upper frames. the bottom bolt on the rear window frame leg occupies the same hole that the rear window track seems to want.
1) trim bottom inch or two of window frame to clear and use just two bolts not three?
2) remove weld nut from window track and slip behind the upper window frame?
3) remove bottom weld nut from window frame and trim window track to fit inside window frame?
any thoughts?
Hank
any thoughts?
Hank
