mjschneidy
- Nov 21, 2016
- 224
Want to share a bit of info I put together while restoring the dash in my 73 Baja. Many threads on code 22780 Parchment being the correct color but the issue I ran into is that it’s a very outdated formula. My local paint shop told me it was discontinued and no longer supported. What that boiled down to was that it is a lacquer only mixing formula and they no longer stock lacquer mixing bases. After bit of persuasion I was able to have it converted to single stage urethane and wanted to give back a bit by sharing it here.
It’s a very good match both color and gloss level. First pic is a test spot against factory paint found on the backside of my dash. Other pics are finished results.
