Tracking down a coolant leak, which I think is my rad cap. It's not leaking enough to even drip onto the ground, but just enough to leave small amounts of coolant on the battery tray and frame rail. Hoses in the area seem all good and clamps have all been tightened up.
As info, I am running a 302 with c4 auto, with a WH Staggered 4 Core rad (connected to coolant overflow tank) and separate trans cooler. Truck is a 71, street cruiser, lives a pretty pampered life now.
The current rad cap looks to me like it has a bit of a nick in the rubber (see photo), so am replacing it. It shows an 18 lbs rating.
From what I can find, most rad caps for the EB's seem to be rated at 13 lbs. Not sure why mine is 18 lbs.
Is there any reason why one would want to run a higher pressure rating than 13 lbs?
Thanks,
David
Thanks,
David
