If you're tired of dealing with the junkie 23 gallon tank sending units here's a new option.
Stainless steel sending unit
No arm or poorly built parts to wear out, the black slide simply free floats on the sealed shaft.
Correct 10-73 Ohm range for early Bronco - Two I have done were dead on, on the other I had to adjust the needle in the gauge as per factory recommendations.
11 inches long (allows for proper clearance and small reserve)
Comes with new rubber gasket and stainless screws (slight larger) but suggest just using your existing screws.
Shipping included.
Shipping included.
