- Sep 20, 2018
- 353
**CORRECTION ON THE TITLE-BRAKE PRESSURE SWITCH TO H BLOCK
So I am getting ready to bleed my brakes and when I went to plug in the brake light switch connector to the H block and when I went to install the connector and the brake line is in the way. I have attached so photos with different anes.
Just want to make sure the brake lines are hooked up right (rear brake line to the driver side and the front brake line to the passenger side).
When you bleed the brakes do you need to have the brake light switch connected to the H block connector while bleeding or do you not connect it while bleeding?
If I am missing something else, please let me know.
Thank you in advance for your time/help,
Sonny
Sonny
