Yep, that pan gasket is good to go for as many uses as you can get out of it. Hopefully only once more!
Did you stagger the main ends about 3/8" to the block surface? Something else I just thought of....clean the block and cap real good and put a bit of sealant where they mate. As you can imagine, oil can seep thru that crack even though it's torqued down to 100 ft. lbs.
