12v direct to the rear for powered speaker
keymonkey
Newbie
I don't believe there is one, but thought I would ask if there was a fused 12v run to the rear of the truck (74)? I have enough wire to run directly from the battery to under the rear seat, but was hoping not to have to drill holes and loom a single 14G wire the length of the under carriage.
ntsqd
heratic car camper
Upper SoKA
Other than the trailer battery charging circuit offered in newer trucks I've never seen that. I've added a battery hot running the rear of the vehicle to almost every vehicle that I've owned in the last 20+ years. Isolated studs are the likely tap-in points, 10 ga wire, fused at 30A
Yep, add your own.
Back then, for a Bronco especially, a “powered circuit“ included a long series of driveshafts and u-joints to a PTO drive mechanism on the transfer case. 😉😁
Jdgephar
Yep, add your own.
Are you suggesting to hook up a generator to the PTO output of the transfer case? LOL
Or the analog version of a flux capacitor! More power to everyone!
Actually, funny you mention generator. I was actually thinking that when I wrote about the PTO. I bet back in the day somebody had one.
