WheelHorse
- Nov 22, 2004
- 2,491
After reading countless threads, most users of an upgraded alternator are b*tching that a single v-belt set up squeals and serp is the only way to go.
So, I ask myself, either the vendors selling this are full of beans because there would be countless upset customers, or people have a heck of a draw on a v-belt system at start up.
I have a stock '77 with 79K miles that I ditched the close to 40 year old aftermarket AC unit, which means I have to buy an alt bracket and spacer. While I had the original alt off I gave her a spin and I could tell the bearings are a little noisy.
So, I took it apart and sure enough the 6203 front bearing is tired and she could use brushes and I'd probably install a new rear bearing. So I could invest 20 bucks into the orig alt and it may last well who knows how long.
I could buy a reman from napa for like 55 and that includes the 5 dollar core charge so I could hang onto my original for keepsake. Plus I installed a new SS regulator last year so I could still use that piece.
OR I could do an upgrade...
Everything I've read said serp is the way to go when having a higher output alt. I've read up on the main charge wire upgrade, losing the amp meter, bypassing the reg wiring, but my biggest concern is the belt squeal with an upgrade.
Truck is pretty much unmolested so it's always a concern with how much do I want to deviate from its originality.
