*Edit: My 1410 is a Daytona style yoke. Am I SOL for installing it on an OEM Ford 9", or do I have to buy new innards.
Hey all,
I put a 4bt and an nv4500 transmission in my early bronco. The slip yoke that was mated to the transmission uses 1410 joints, so I purchased a 28 spline 1410 yoke for my 9". HOWEVER, when I was test fitting it, I noticed I cannot get it to engage the pinion, as the shaft is too long for this yoke and the nut bottoms out leaving around a 1/4" gap and play.
Is this normal thing, or is the only 9" 1410 yoke on the market not machines right? I lined up the original yoke and the new one, and the 1410. The original has about a 1/4" more length of splined section. Is there a spacer or something that I'm missing?
Right now, I cannot tighten it to remove slop because the nut bottoming out on the shaft, and not the yoke.
I plan on getting my rear end regeared, so I just need to make sure this yoke is usable in the meantime.
Hey all,
