I've always been told that an engine running too cold is a bad thing.
I have a 351 in my '74 that was in there when I bought it. According to the stock temperature gauge, the operating temperature is around 150 degrees.
Thinking this might be a gauge issue, I used an infrared digital thermometer to take the temperature reading at the intake manifold near the temp sending unit. Sure enough, digital thermometer reads between 150 and 160 degrees.
I have no idea what thermostat is installed or if there's even a thermostat in there.
On top of this temperature issue, the oil pressure is pretty low. Stock sending unit and gauge. At 70mph on the freeway, the gauge reads in the lower quarter to one third. In my experience, it should be about halfway up the gauge at freeway speeds.
I'm curious if the low temperature of the engine is not heating the oil up enough to flow correctly and is negative impacting the oil pressure.
Curious what the experts here think about both of these issues.
