la hi
- Feb 11, 2014
- 103
I have replaced most of the steering stuff and added a 2.5 inch lift. The shaft that goes into the steering box has too much play. You can turn the shaft by hand easy, it moves the steering wheel and it stops in the box. The box doesn't move. and the result is over correction steering by the driver.
If the shaft fit tight into the box the problem would be solved.
Is there a way to tighten the shaft going into the box?
