lonesomecur
- Joined
- Dec 7, 2007
- Messages
- 336
This was a running and driving bronco that I started removing parts from for another project. It has a 289 from a 68 in it. Standard bore and standard crank. rebuilt with edlerbrock cam, lifters, and intake, headers in good shape. HEI distrubuter and accel wires. NO carb. I have the complete 69 302 engine disassembled that needs machine work. It is included.
Body is rough with patch panels in floors rivited in. and other places. Doors are ok with all glass. Top is good. Body has cut outs for rear shocks and different trans as seen in pics. I have pieces to weld back in.
Wiring harness has a burned wire so probably needs replaced. Does not charge battery. Other than that everything electrical worked. I can show you wire very easily.
Many newer parts: HEAVY DUTY OUTPUT SHAFT in transfer case from WH.
all body mounts and bushings have been replaced. stainless mufflers from flowmaster. new bearings in front and rear differentials. POWER STEERING FROM DUFFS. DRIVE SHAFTS FROM DUFFS. STOCK HEIGHT SPRINGS
NEEDS: body bolted back to frame and everything hooked up. doors and top installed along with seats. Carb and radiator are missing. I removed disc brake conversion and installed drums to roll around but not hooked up.
Please contact me via email.
StevenBenefield@comcast.net
I have pics but haven't figured out how to post yet.
