- Mar 21, 2024
- 152
Hi Everyone,
First off, I want to preempt too advanced feedback (lol) by stating I am an amateur eager to learn.
Current Setup: 1970 302, Manual Transmission, Autolite 2100 2b Carb, no a/c
Recently redid the intake manifold gasket due to leaks out front passenger side corner and rear. Prior to intake manifold job, the truck idled too high. Would take forever on a semi cold day (mid 35 F) to step down. Sometimes "accelerating itself" even after warming up.
Post intake manifold job by mechanic, truck is stalling under a few circumstances: when approaching a stop light, shifting from third to neutral it seems to slowly stall upon approach as idle drops. When switching from 3rd to 2nd gear around the lower rpm band of third gear to drop it into 2nd. From neutral into reverse or slipping into 1st, need to rev up a bit.
The mechanic noted that the double port vacuum advance needs to be replaced. I am wondering if PO had idle set high because of what appears to be a mess of vaccum lines.
The Goal: Straighten out all vacuum lines and correct normal idle.
1. I have been trying to find a detail vacuum diagram. I found a manual for the 2100 if anyone is interest: Autolite 2100 Manual
2. What is the best way to diagnose and tackle this?
3. Do you know which vacuum advance for the distributer I need to buy?
Media Link: https://drive.google.com/drive/folders/1DPiCXVG1rf8DJeLH3_NdG-T82_UZKeux?usp=sharing
