- Apr 12, 2020
- 30
Hey everyone! Figured it’s time I get a build thread going. I’ve had my bronco for about 9.5 years and daily drive it for 7 of those years. I’ve decided to swap a bmw diesel and automatic transmission into it and as you’d expect the project scope seems to increase indefinitely.
The engine: the engine is an m57 diesel found in the 2009-2011 bmw 335d sedan and the 2009-2013 bmw X5 diesel. It’s a compound turbo 3.0 inline 6 with dual overhead cams. The block and head are aluminum and it comes stock with all forged internals. It’s one of the most reliable and overbuilt engines bmw has made. With the stock turbos and high pressure fuel pump you can expect 440hp and 700tq at the crank with a tune once you remove all of the emissions stuff. This is essentially the configuration I’ll be running. It should get around 30mpg on the highway but time will tell.
The transmission: the transmission is a bmw zf8hp70 made by ZF. It’s an 8 speed transmission from the 2014-2019ish bmw x5 diesel. These things are super robust, shift extremely quick and smooth and are being use by every major car maker now. You can find them in everything from a dodge ram to a Lamborghini. The bmw variant has the largest output shaft and smallest bell housing making it ideal for this swap. There’s actually a good amount of support for this engine and trans combo in Europe which is where I sourced the adapter plate.
Transfer case: I’ll be using the ATC45L transfer case that comes in the BMW X5 and blurs right up to the trans. It doesn’t have a low range but for what I do (mostly city highway and desert) I’ve never needed low range.
This project has made me super thankful for this forum as well as any other classic car and off-road forums I’ve been on in the past. Turn out BMW guys are generally super unhelpful and reluctant to share knowledge, essentially the opposite experience of what I’ve had here.
I’ll slowly start to add more info and post updates about things I have completed on this build and my progress going forward!
Happy to answer any questions and take any suggestions!
