- Nov 3, 2003
- 49,211
What can it hurt to try bumping the timing? Pretty much nothing, as long as you know what you're doing and are careful to note how it drives afterwards.
What is your initial timing set to currently? I think you said 12-13 or so? I say go for it.
Set it to 15-17 and see what that nets you in driving. Does it ping under load with that much advance? If not, then run it for awhile including with the vacuum advance connected and see what it drives like.
Which carb is this again? Rebuilt, reman, new? If it's been worked on by anyone but you, you don't now how the throttle blades were zeroed unless you check. If they're not perfectly centered in the bore they might be hanging up the linkage.
By the same token, your choke linkage can hang things up to the point that the idle-speed screw no longer does anything beyond a certain low point. So check that too. Make sure that the high-idle screw attached to the choke linkage is not too far extended and hanging up on the choke's high-idle cam.
Either one of those can get the carb wonked up to the point you can't close off the transfer port for the advance.
So verify that nothing is restricting the closing of the throttle blades. Then get the higher idle however you can initially (600-650 is a good point, but frankly 500-550 is not completely out of line) through timing and verifying the idle speed screw is doing it's job, then see what happens.
Seems to me that you should be able to stall the engine by turning the idle speed screw out to the point it's no longer touching the throttle lever.
I'm sure there are legitimate scenarios where you can't fully stall the engine, but I can't think of anything other than something wrong with the carb.
You don't have a throttle control solenoid, do you? Sometimes known as "emmissions soleniod" or "anti-dieseling solenoid" or maybe another name or two, but it's also used for setting idle parameters. So if you have one, make sure it's not creating trouble for you as well.
