- Joined
- Nov 28, 2001
- Messages
- 10,571
Different guy. Mono's first name is John.Not sure if he is on here. But it was a guy named Chad outside of Duluth, MN. He's had 4 or 5 Broncos on ebay the last few months.
Todd Z.
I learned today that the Bronco article should be in the January issue of Hemmings Motor News. Vern says it will be on the cover!Todd,
Very interesting read, thanks for posting up the link. Do you know if the article is in the print version? Would love to know the breakdowns of the numbers on the other ‘72 Ranger colors if that info is available. My ‘72 is Limestone Green, like Brandy’s.
Todd Z.
that is one i will chk outA new article in Hemmings on a "P and Q" truck:
https://www.hemmings.com/stories/unrestored-1972-ford-bronco-ranger/
I'm surmising it is anyway, based on the production date, etc.
Todd Z.
I've been working on an accurate VIN chart (VIN vs month/year built) for some time. One problem area that I've seen on all published charts is late '72 and early '73. This is the P and Q zone. Every now and then I'll see a VIN pop up that doesn't seem to fit in these charts. I have collected some data points to prove these other charts are wrong but I don't have enough data to populate an accurate chart.
This is where you can help. I need just 3 or 4 characters from the VIN starting with the P or Q. You don't need to post your entire VIN. For example, for VIN U15GLP12345, I need the characters "P123" and the build month. The build month can be from the tag on the driver's door post, Marti report, or Ford build sheet. It needs to be from a documented source not your aging memory of when your think your uncle bought it off the dealer lot.
Thanks for the help.
6/1972. P375. Sport explorerI've been working on an accurate VIN chart (VIN vs month/year built) for some time. One problem area that I've seen on all published charts is late '72 and early '73. This is the P and Q zone. Every now and then I'll see a VIN pop up that doesn't seem to fit in these charts. I have collected some data points to prove these other charts are wrong but I don't have enough data to populate an accurate chart.
I don't know if mine will help any or not as mine is an early 72 build a "N" VIN #. Here is my Marti Report.
Very nice, concise summary - after I read the exchange on FB, I figured this might be comingBringing this thread back to the top. It has been 10 years, 31 pages, and 609 posts...and we still don't have resolution on the p's and q's. Mostly because we have some very credible resources making some definitive statements, and there is minimal data to refute those claims.
But I have evaluated the data compiled by @Viperwolf1 and I am ready to make an unpopular assertion.
For the production period of August to December of 1972, here are some observations:
1. If you received a Bronco with an automatic transmission, it had VIN Q.
2. If you received a Bronco with a VIN Q, it was equipped with EGR.
3. If you received a Bronco with a VIN Q, it was certified to meet 1973 Emissions, and the Certificate of Origin, Registration Year Model, and Marti Report indicate that it is a 1973 year model.
4. If you received a Bronco with VIN P, (after P88xxx) it was equipped with a manual transmission.
5. If you received a Bronco with VIN P, (after P88xxx) it was not equipped with EGR, and would not meet 1973 emissions standards.
6. If you received a Bronco with VIN P, (after P88xxx) it was certified to meet 1972 emissions and the Certificate of Origin, Registration Year Model, and Marti Report indicate that it is a 1972 year model.
If we can agree to the previous 6 observations, then it is reasonable to conclude the following:
Production of the 1972 year model Ford Bronco began in August of 1971, and ended December of 1972.
Production of the 1973 year model Ford Bronco began in August of 1972, and ended July of 1973.
For three months, from September of 1972 to December of 1972, there was concurrent production of TWO different year models of Bronco. This was not an accident, not an anomaly, not a production error.
Generally speaking, the year model change coincides with the plant re-tooling shutdown in July. But it is not absolute, and as stated by @DirtDonk many years ago...not a regulatory requirement. You could buy a 1999 F350 in March of 1998. And you could buy a 1965 Ford Mustang in April of 64. They were making 1965 Sunbeam Tigers all the way thru December of 65. And Shelby tried to build 1967 Cobra's 40 years after the factory shut down.
If anyone with a VIN P88xxx or higher could post a pic of their Emissions decal that states "For 1972 model year" That would put this to bed. And I can stop arguing with @JGbronc
There are examples in the database of August, September, and October built Q VIN manual transmission Broncos. So the Cert existed.I also mentioned in the past, that it was very possible that they were unable to meet certain emissions requirements during the latter months, so kept registering them at 72s.
At the time I thought it could perhaps be the availability of EGR parts, or certain other components.
But another possibility is that they had not achieved certification with manual transmissions yet.
If you remember a lot of vehicles back then, let’s use the Pontiac Trans Am as an example, in certain areas like California you could only get an automatic transmission and it only came with the Oldsmobile 401 (or was that a 403?) whereas in other states you could get the manual transmission with the Pontiac 400.
So that’s just another possibility in the emissions category.
Lots of vehicles back then had different horsepower ratings between automatic and manual, and other differences.
Do we already know from the data whether any of them were sent to CA?There are examples in the database of August, September, and October built Q VIN manual transmission Broncos. So the Cert existed.
OK, you are right. It's an anomaly.Very nice, concise summary - after I read the exchange on FB, I figured this might be coming.
I will take one exception with your conclusion though, where you state "This was not an accident, not an anomaly, not a production error." I'll counter and say it is an anomaly since it only happened once in the first 30 years of Bronco production (1966-1996) - with the definition of anomaly per the internets being: something that deviates from what is standard, normal, or expected. Since it only happened once in those 30 years, I'd say it's not standard, normal, or expected.
We all know it happened - that's been very well vetted and documented in the past 31 pages. As a history geek, I'm curious why it happened and as an engineer, I'm curious if, as we suspect, it was related to either a parts shortage issue or perhaps a calibration/certification issue for manual transmission trucks. I'm guessing most anyone that would know such things is long gone and there probably wasn't any documentation that survived that provides any clues either. I don't think it can be put to bed until we know exactly what happened and why it happened.
Todd Z.
The data are inadequate. There is only one CA DSO and it is an October production 1972 Bronco. There are zero CA DSO 1973 Broncos in the database.Do we already know from the data whether any of them were sent to CA?
In reference to Item 1 are you suggesting all Q are automatic? My Q VIN is Trans Code C, J shift, Built 12/72 for 73 model year per MartiBringing this thread back to the top. It has been 10 years, 31 pages, and 609 posts...and we still don't have resolution on the p's and q's. Mostly because we have some very credible resources making some definitive statements, and there is minimal data to refute those claims.
What’s funny is, I agree with everything you said. But I still firmly believe those late built “72s” would be 73s if they had met emissions standards for 73.Bringing this thread back to the top. It has been 10 years, 31 pages, and 609 posts...and we still don't have resolution on the p's and q's. Mostly because we have some very credible resources making some definitive statements, and there is minimal data to refute those claims.
No, you are stating the converse.In reference to Item 1 are you suggesting all Q are automatic? My Q VIN is Trans Code C, J shift, Built 12/72 for 73 model year per Marti
Got it thanks, that's what I suspected.No, you are stating the converse.
If you had an Automatic, it was a Q.
That does not mean that if it is a Q, it is an automatic. Plenty of examples in the database of manual transmission Q's.
