- Nov 3, 2003
- 48,106
...I was also thinking of ordering an adjustable tracking bar, any other parts you would suggest with the 3.5 suspension lift that I did not list previously?
I think the adjustable trackbars are a great item, but it's only "needed' if your axle is currently off-center even with a drop bracket.
If I remember from the previous discussions, you do have the drop bracket and the dropped pitman arm, correct?
If so, then a general list follows. But those two items would be the key.
The NEEDED items:
1. Pitman
2. Trackbar bracket (except on '76 and '77 EB's with converted steering linkage)
3. Soft brake lines from the frame to the axles.
4. Parking brake cables (but only if you wheel it)
5. Offset C-bushings. Likely 6-7 degree for most with 3.5" lift.
Some OPTIONAL items:
1. Adjustable trackbar. Needed to fine-tune the axle centering, and it does make it easier to install.
2. parking brake cables (see #4 above) if needed.
3. Longer radius arms only if longer travel or potentially softer ride (with side effects) is desired.
4. Lower rear radius arm brackets. (only if C-bushings are not desired or sufficient) again with side-effects.
5. Trackbar riser (instead of a drop bracket) if needed or desired, depending on usage and other changes.
It's all I can think of at the moment. From the discussions, I think you've already got the basic necessities.
