- Joined
- Jan 28, 2011
- Messages
- 894
It's in CAAwesome truck Andy, congrats!
Better add this thread to the lowest mileage Bronco thread for reference.
Is it in MO now or CA? I would like to see it some time!
Back in 2006 when it was purchased from the original owner and put in a warehouse the new owner cleaned it up so all that dirt is long gone.
He parked it and it didn't move until April of this year.
Here is more from Andrew's report:
"The brake system has been cleaned and wheel cylinders replaced, but are otherwise original. The original wheel
cylinders have been retained in a box for later re-installation if desired.
Besides the fuel tanks having been out for cleaning, the only change from original is that the underside of the truck
was cleaned with an abrasive and sprayed semi-gloss black. The seller told us that the Bronco exhibited some
surface rust from sitting so long at the rental property carport for all the years leading up to his purchase. The
carport he pulled it from had a dirt floor. Tall grass had grown up into the undercarriage causing generally dirty
conditions. All axle tags are present, and the underside shows no current signs of rust or rust pitting."
This is all good, but, I got to thinking, what do you do with it? What do you do with the lowest mileage Bronco on the planet, is there another one?
Would I like to own it? But of course.
It would still be the same dilemma.
I had / have the same thoughts. At the end of end day I decided the opportunity to get it was something I just could not pass up.
The Bronco isn't pristine (well, a lot of it is ), but that just shows how it was stored outside in Missouri for all those years.
My plan for now is to keep it clean, make sure it runs, document everything as best as I can then show it around when possible.
So is this the lowest mileage Bronco discovered in the last 10, 15, 20 years? Are there are other sub 1,000 mile Broncos?
No Ranger on the tire cover? Wonder if it was replaced or some Rangers came without it. Todd Z?
Todd can probably shed more light on it, but it seems like many of the '73 Rangers had the cover that is on Andy's. I have a NOS one like the one pictured without the bucking horse graphic and it just says "Ford Bronco". It has the orange piping like Andy's also. It seems that the orange piping came about with the Ranger package and the white and red-orange vinyl striping graphics on the body and hood. The orange on the cover was a match, but it took a little to get the "Ranger" and the bucking bronco on it.
Fordfan is correct - it's been my observation that a lot of the '73s have the 'Ford Bronco' lettering on them. The '73 brochure doesn't give any clues. The '73 Data Book mentions both. In their 'New Things for the '73 Bronco' page, it says the tire cover is like this one with 'Ford Bronco' on it. In the Bronco details pages of the book, it lists the tire cover as having 'Bronco Ranger' on it. In the Brooklands book of road tests, Bill Stroppe's personal '73 Ranger was used in a road test for a '75 article and it's shown with the 'Ford Bronco' tire cover too.
Todd Z.
