Thanks Guys!
Yes - my next move (today) is to revisit the toe and target the front side measurement to 1/4 - 3/8" less than the back side measurement.
Depending upon how that acts and feels, I'm going to get a drop pitman arm and was planning on going with the "drop" track arm bracket versus the "riser" type just because I don't have welding capabilities here and I assume the drop bracket is a bolt on.
My track arm bar and steering link are pretty much perfectly parallel but I really get the whole "too much angle" on both deal. The way I'm viewing it in my head now is: when I turn the steering wheel, the steering link is trying to drive into the ground instead of pushing laterally but because its physically attached to the tie rod, it really has no choice but to go side to side - still, its natural direction of movement is down at the present angle - so I'm probably getting a jerky down/side to side when I'm cruising and the Bronco is bouncing around on uneven roads - exactly what it feels like anyway. As for the tack bar, the whole principle of it is to control & maintain the horizontal centering relationship between the dana 44 and the frame and the greater the angle its sits at, the more compromised it becomes and the less effective it is, i would imagine - what I mean is, there is probably a magical angle that if exceeded, the track arm might actually pull the front end toward the driver side and purposely cause off-centering. I don't think I'm even close to that but when a 3000 lb Bronco with 33s starts dancing on a pothole filled road, who knows what happens with that angle??
The bottom line in my mind right now is: get the steering link and track arm bar as flat to the ground as possible and keep them parallel with each other.
thanks to everyone for their thoughts. other than getting another Bronco (this is my second), meeting my wife and having two great boys - joining this forum was one of my best moves!
hats off and many thanks to the entire CB.com community - you guys & gals are great.
DJs74
Welding the drop bracket after its bolted is a must. But, I bolted mine in and was able to take it to a muffler shop and they welded it in for me for like 15.00. Money well spent and I didn't have to have a shop install or loose any driving time. Just a thought.......
