1974 hazard flasher light wiring
hyghlndr
Hockessin, Delaware
I been around the block but this one has me stumped....Does anyone have a wiring diagram for a 1974 Bronco harness ? I simply can't find the hazard blinker and wires??? I did easily find the turn signal blinker.
Having the colors of the wires and routing would help.
Viperwolf1
electron whisperer
It's real close to the turn flasher. Turn flasher connector is blue and hazard flasher connector is black. Wires are red-white and white-red.
Unless it's missing of course!
Do your hazard flashers currently work? Or is that why you're hunting things down?
H
hyghlndr
Hockessin, Delaware
No they do not work. I have been under a bunch of dashes but this one seems to be missing everything. Viperwolf1 at least I am sure of the color of the wiring but I may have to figure where they feed from.
Does power come directly from the fuse box?
Where should the power go to when after leaving the flasher canister?
Just to be clear, is your hazard switch in the dash like the early models, or on the steering column like the later models?
Plenty could have been changed over the years, and your '74 is the changeover year anyway.
Have you checked all of your fuses yet? Power comes in from F5 on the Red w/white wire to the flasher, then out to the steering column (on later years) through the White w/red wire.
Early style would have the same color wires, but obviously it would go to the dash switch first, instead of straight to the steering column.
