bbow
Had the same problem and finally realized my fuel gauge was way off. If I have less than 2 gallons of fuel and hit a hill then it starts sputtering.
Have you by chance looked at the 1405 owners manual? Here is the link from Edelbrock's website.
http://www.edelbrock.com/automotive/misc/tech-center/install/1000/1405_manual.pdf
I see you have adjusted the float, referencing page 15 should help you get it back to where the float should be.
What is the condition of your ignition system? Bad plug wires, cap & rotor can cause it to stumble under load.
This. Have you checked your coil? Ballast resistor? I had this same thing happen and it turned out to be the coil. Oil dribbling out and all.
Try a known good carburetor and see if that will eliminate the carburetor as the issue.
From your description it is either a leak in the fuel line between the tank and pump or a bad condenser or points if that is the ignition system you have. If there is a leak on the "suction" side it will sputter like heck. A weak spark will cause sputter on acceleration and could be because of bad coil, points, or condenser.
How I would handle it.
1. Install a fuel pressure gauge (need to confirm good fuel pressure after filter)
http://www.summitracing.com/parts/mrg-1564/overview/
2. Open distributor and check everything is tight (especially ground wire)
3. Replace the coil. (these are oil filled and can leak and breakdown over time)
4. Swap carb
5. Call Priest
Now that you have the pressure gauge installed. Next time it is doing this, check your fuel pressure as it is stumbling. It might be a little harder to tell since you have a mechanical fuel pump (and if your engine is stumbling, you fuel pressure may be as well, IDK?).
Do any of your fuel lines run anywhere close to your exhaust? Especially where the fuel line is routed past the drivers side manual? I have SS lines and insulated them from the manifold heat.
How is your distributor cap and rotor? Even a hairline crack in the cap can wreak havoc, look to a carbon trail.
Could you post a picture of your engine compartment? A picture of how you have your carb linkages setup would help, as well as your distributor and wiring.
