I'm starting to plan a fairly extensive suspension build on my 75 and would like to get some input from people who have experience with long-arm coilover setups and stretching the wheelbase.
Going to be using the Tom's Offroad Long arm Coilover setup front and rear, and performing a stretch. Before I start cutting and fabricating, I'd like to get some feedback on what has worked well for others and what you would do differently. For context I'm planning a 351W for now. Hoping to keep the car as low as possible, likely a 3" lift, and a 1-2" body lift.
If anyone has insight on the following I would greatly appreciate it.
Any pictures, build threads, measurements, or recommendations would be greatly appreciated. Thanks in advance!
- Front Stretch: Planning on stretching 3-4 inches forward. Crossmember, shock tower and coil buckets are all getting cut off and moved/changed. Any recommendations on if that long a stretch will cause issues with the steering rack interfering with the stock grill. Also if planning to run 35/37s will they rub the body mounts? I've seen different setups and would like to hear what people have found to be the sweet spot. At what point do steering geometry, track bar placement, frame clearance, or other factors become a headache?
- Rear Stretch: How far would you recommend stretching the rear? Looking to balance street drivability and crawling performance while maintaining a somewhat factory look.
- Wheelbase: What overall wheelbase have you found works best for an Early Bronco intended for a combination of trail use, crawling, and general off-road driving?
- Things You'd Do Differently: For those who have completed a similar build, what would you change if you were starting over?
