1975 potential purchase question
TheChiro
Hope everyone is doing well. There is so much great info on here and I'm learning as much as I can. Have a question about a potential purchase.
Looking at purchasing my first Bronco and have seen this one on CL for a while now. It definitely needs new wheels and tires and windows installed, but as a project does it look like a short list or is this a money pit, based on what you can see/tell?
I have spoken with the seller and he's open to offers...it sounds like he bought it and realized he doesn't have the time or energy to do much to it. If I can get it for the right price is this a good starting point or should I spend a little more upfront and get one in better shape? This is a 3rd truck for short around town trips and the occasional trip to Tahoe, from the Bay Area.
https://sfbay.craigslist.org/eby/cto/d/oakland-1975-bronco-daily-driver/7006029629.html
Thank you all for your time.
okie4570
NW OK
Welcome, fuel injection and auto are a bonus, but I'm still not seeing $20k worth of bronco there on that one.
T
TheChiro
Thanks! Since he's open to offers, what do you feel a reasonable price would be that's worth taking the chance? 12k?
Now that I am home and can see the pics on a bigger screen, the worse it looks. First two things that catch my eye are body lines. Ignoring the caved in tailgate from the spare tire carrier, the tailgate bedside gap is horrible. And it isn't the tailgate that is off, something is seriously wrong with the body side. That is in the left rear corner, the right front doesn't look much better. Just looking at the hood to grill something is really wrong there as well.
The ignition switch is missing, looks like the front of the cage is welded straight to some floor patches. Even the picture of just the tire bothers me. Looks like that is the left front, there is a huge directional arrow, and it is pointing the wrong way.
There is a roll bar gusset that looks like it is about to take out an eyebrow. I'll be kind and say a creative use of angle iron on the main hoop of the cage. But I don't see any weld on the drop track bar bracket. The bottom of the mustang oil pan looks about as mangled as the front brake line on the axle.
Looks like the bump stops have been ignored, if this were to ever flex out, if it could even flex, there would be big rubbing. Or I you just hit something bad and came close to bottoming the suspension things will be bad. Looks like the absolute minimum that could be done to install large tires was what was done.
The underhood is a whole new level of just barely functions. The computer is neither weatherproof enough to be in the engine compartment nor designed for the temperatures under the hood. That EEC-IV computer always lived in the passenger compartment. It looks like there was an attempt to seal it in a food container, but that has broken. There is no air filter, not even a bad filter. Alternator looks like a 2G, which is expected for that generation of motor. The 2G is about as bad of a choice as you can make. The plug is well known for failing which if you are lucky is only a fried harness and alternator or it could just burn everything.
At this point the missing heater box inlet doesn't even bother me. This is not a daily driver. This is a beater. Depending on what you are expecting to do with this as a project, even $12k I think is high. Lack of (visible) rust is a good thing. But the fact the body is so twisted up might be even worse. What is under the new skins? In the words of CW McCall, "I've seen better looking stuff in the junkyard".
If you are looking for an easy fun project that you can tinker with a little, this isn't it. To make this one really clean would take a LOT of work. The looks of the engine install doesn't inspire the fact the engine is a quality piece. And that puts the transmission in the same category. It may be there, but what pick and pull yard did they get it from? I am sure they are not fresh. Probably functional, with a completely unknown history.
sprdv1
REBEL
Wait for a better one to come along, Broncobowsher got the knowledge and other opinions likely will be the same
Good luck
#patienceiskey
Bferrari
I was thumbing through the wants adds of the Shelby County tribune when this classified advertisement caught my eye ..... Lol!
TheChiro - what’s your end game? Are you looking for a beater or want something you can make nice? May cost you quite a bit to straighten out everything on this one.
