1975 VIN DECODER Issue
crmoore
Bonney Lake, WA
I recently purchased an excellent condition 1975. 92,000 original miles and Garage Kept its entire life. I am having trouble decoding the VIN. My Glove box says that it is U153 with Body 34 and Axle 18J. I cannot find this interpretation anywhere on the decoding websites. Bronco Ohio has been the most helpful, but still can't find this info. Any Help would be appreciated.
DebosDave'72
Bozeman, MT
The only thing I can find on an 18 code is a 3.50 rear end, usually a 2780#. The only thing I find on a "J" is for the front axle, and means a 2500# axle with limited slip. This is weird though because I can't see them putting a LS axle up front when there isn't one in the back. The only limited slip rear ends have a "alpha" character in front of the axle code... (ie. A5J)... The all numeric code for the rear axle means it is an open dif from the factory, without exception. That doesn't mean someone didn't put something in there after market. I have just seen an explanation that states the "J" could also mean you have power steering (Do you??). The U153 is the GVW rating, it is one of the middle ones, the U152 is the heaviest... I am guessing the U153 indicates the same 2780 axle... I don't know what the body code is, but I think by 1975 they were only making a wagon, so it may refer to it being a sport or ranger... something like that??
Hope this helps a little...
Dave
C
crmoore
Bonney Lake, WA
I do know the GVWR is 4500 with a Front Axle of 2350 and Rear of 2360. I believe I do have 3.50 rear axle as it is indicated by the original owner in his handwriting when it talks about the rearend in the original manual. One of my questions was why this model is not indicated in any VIN Decoder I have found on the internet? Another question is "Do they all say MPV on the original Glove box VIN?" I haven't been able to get the truck up on blocks in 4x4 to verify the differential is limited slip or not. Anyway, I appreciate the help so far.
BG's 68 Bronco
body 34 might be your interior color - I think 34 is a white?
best thing to do is spend $40 and get a Marti Report done if you're really interested in the history of your Bronco. I did it and the information is invaluable to me!
www.martiauto.com
ken75ranger
Troy, NY
I have a '75 Ford manual. U153 is listed. As you thought it's a 4500 GVW.
18 with no letter is listed as 2900 lb. 3.50 gear Ford rear end.
J by it self is an unlisted front axle with power steering.
The 34 for the body means
3- Parchment/Ginger
4- Rear seat
fastback
Asheboro, NC
I also have a '75 U153 body 34 my Axle is a B90 ,color code is M. M is for wimbledon white. I do have the rear seat and the seats are the parchment color which would match what ken75ranger is saying about the body code 34. I think the numbers on the tag of my d44 and rear end indicate that both are Limited slip. unless someone has changed somthing you may be able to look at the tags on your d44 and rear end. I think they will have an L or LS somewhere in the numbers to indicate Limited slip.
