1977 info
DonH
WA State 30 miles from the beach
I purchased a 1977 Bronco from Facebook a couple of months ago. It had been shipped to WA state from Hawaii about five years ago. It set out until I brought it home. I have copied numbers from the VIN and the rear axle and was hoping to get some info. The rear axle WFR-83 7ED 3L50-9 695F 04600 1977 72
The Vin Tag U15GLY76782 0921 U151 RV C 88 J
The rear axle seems to have a Posi and it would be nice to know the ratio.
Don
stanley weiler
the L between the 3 and the 50 is limited slip and 3;50 is the ratio unless i am wrong but that how we always found it
Stanley is correct. 3L50 indicates a 3.50 ratio with a factory limited slip. Though “Posi” is GM vehicles only.
Assuming it hasn’t been changed.
You say it appears to have a limited slip, which indicates you’ve checked in one way or another. Some of those ways also make it easy to check the current ratio.
You can confirm the front ratio easily enough, when you change the gear lube.
Because when you get a vehicle that’s been sitting and has been in harsh environments (think Hawaii) it’s always a good idea to change the gear lube just to make sure there’s no water and no damage to the differential.
At the same time, you can simply count the teeth on the ring and pinion gears and do the division.
okie4570
NW OK
B8J is 3.50LS and open front Dana 44 with power steering. All 76 snd and 77 were big bearing 9" rears as well.
DonH
DonH
When both wheels are up and you turn one wheel and the other turns the same way it may mean it has a limited slip.
Viperwolf1
electron whisperer
Interesting. In '69 B8J is listed on my Marti as "3.50 Limited Slip Rear Axle with Dana 30 Limited Slip Front Axle". And indeed, my Bronco has limited slip both ends.
The axle codes changed over the years. In 1969, B8 would have been a small bearing, limited slip, 3.50 geared rear axle, and since there was no power steering available J would have indicated a front limited slip.
okie4570
NW OK
What Viper said above. The same codes varied through the years. This one would have been B9Q if it was 3.50 and LS front and back and power steering.
Speedrdr
Legend in my own mind
Paris, MS
And my luck was to get a 77 with a lousy 18J open differential. I have the parts to change “my luck” to a locker.
