1977 Stock Tilt Steering column?
Bueffjuice
Still new to EBs and just got in a 77 and noticed the steering column was positioned low and I'm able to lift it upwards but it won't stay up. So I'm trying to figure out if it has some kind of stock tilt steering column or if the bracket that the steering column bolts to actually has broken from the metal above it under the dash? You can see the green (original color) bracket in the pics the steering column attaches to. Other than the plow mechanism this is a bone stock EB. My gut is telling me the green bracket is broke, but figured I would check here first before I go taking the dash out! I tried to look from under the dash up but I darn near pulled a fat bubble trying to contort my body into the figure 8 position required to do so...
Let me know what you think! Thanks
Should be 2 pictures on flickr site.
https://www.flickr.com/photos/183852791@N08/51206376930/in/album-72157719329180980/
Ohio, plow, I guess you have a lot of rust?
The green part is part of the dash structure. Best I can tell the bronco has been repainted in red, green was the original color.
No, that is not a tilt column. No '77 ever came with a tilt column. Some people have swapped them in from other vehicles. But the part that comes through the dash is fixed. The hinge is located between the dash and the steering wheel.
Take off what's left of that broken black plastic steering column surround and start inspecting. I suspect it is going to be very ugly.
Bueffjuice
Bueffjuice
This 77 actually came from MI, a 1 owner and yes original color was green per VIN. The rust is hit and miss, some good some not so good. It seems like an odd place to rust, the steering column bracket. Especially with the dash being in good shape and the engine compartment isn't bad. Weird.
Well sounds like I'm gonna have to work on getting that dash off and seeing what I have to deal with! Thanks for the info!
chuckji
SE Michigan
Your steering column is going to have a mount like this and it’s going to bolt to that green dash structure as Broncobowsher stated.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The stock bracket looks nothing like that. It wraps around underneath the column in a U shape. You can see it's intact in the OP's first photo.
When you say you can lift the column up, is it being lifted up in the photos? In the photos it appears to be in the stock location where it would sit if bolted in under the dash correctly.
jckkys
There is no reason to take the dash off. If the 2 bolts that secure the column aren't tight, see why. The plastic is basically cosmetic but the fact that the plastic is broken likely indicates movement of the column. That should be solidly bolted to a heavy brace under the cowl. Your bolts may have come loose or stripped the threads on the nut welded to the top of the brace. I don't see much of a gap if any. So repair won't raise the wheel more than 1/8". The diameter of the stock wheel is excessive. So a smaller diameter wheel will give you more room over your thighs. I like a 15" wheel on my '77. I'm guessing you have power steering on a '77. With that the giant 19" stock wheel isn't needed or desirable. Ford got around to making a smaller steering wheel in '78. So I put a '78 column on my '77. Once the column is secured I would replace the column cover. They're available in plastic or billet. Your impression that the column is low, is just that. They were made that way.
Bueffjuice
Bueffjuice
Ok with all the input I went back and checked the Bronco out again. The Steering wheel is not far off the seat I would guess 3-4 inches(couldn't find tape to measure). I can grab the wheel and lift it up another 2-3 inches, and move it maybe 1/4 to 1/2 inch side to side.
So I decided to look under the dash and I can honestly say I've never seen anything like this before. I can clearly see the U clamp that holds the column onto what looks somewhat like an "S" shaped metal bracket. And above the S bracket is rusted but what I find odd is the S bracket looks preformed like it was made to sit/rest in something? I'm not sure, but it doesn't look like it was made into the upper part is what I'm getting at. It looks separate but was somehow attached. You can see in one of the new photos I can get my fingers between the S bracket and the upper part.
I've updated the photo album w/under dash pictures: https://www.flickr.com/photos/183852791@N08/albums/72157719285143491
Rust and broken welds. When you lift the steering wheel up that gap should close up.
Never seen that one fail before.
Bueffjuice
Bueffjuice
I found a picture online of someone doing a restore and can see the steering column mount that is broke on mine. I added the picture to my online album. Not going to lie I was expecting this area to be a little "beefier", it doesn't seem like much. I think the worst part will be getting the dash out and discovering what other issues are waiting on me!
Oh well guess it's time for me to get my first taste of working on an EB(been a Jeep guy for years) and get that dash off and start doing work!
Thanks for all the input, I'm sure I'll have more questions to come as I dive into this jewel!
Hint, remove the column first.
Phillips screw that looks random in the center of the dash, that holds it in.
Windshield knobs like to twist off if they are rusted in place.
Trying to remember if you have to fold the windshield, I think you can pull the dash with the pad in place so you don't have to fold the windshield. Been too many years since I pulled one.
langester
MASTER OF MADNESS
I had a similar problem. I missed a weld when repairing my cowl which left the bracket hanging down on the back side. I didn't want to weld it and screw up the paint. I fabricated a plate to catch the two bolts that go up into the cowl and fixed my problem. Not sure if this will help in your situation but might give you an idea to get it patched up for now. Here is a link to my build thread with pics of what I did. Hope it helps, good luck!
https://classicbroncos.com/forums/showpost.php?p=3162470&postcount=186
jckkys
You've got a lot more rust damage than I imagined. To tie everything together and have some structural integrity a new cowl would be needed. When I lived in Chicago, a friend had a unit body car literally rust in half except for the roof. The floor fell onto the drive shaft. Any off roading makes a solid EB twist. The frame on EBs rule out the floor breaking, but with all that rust, more things are likely to come apart.
Bueffjuice
Bueffjuice
Ok got the windshield down and dash off. langester your pics made me realize what I was missing, my upper part of the windshield cowl mount is gone! Btw I like what you did on yours liner/color and your bracket, looks good.
jckkys yeah I'm with you, I'm not looking to trail ride but mainly for now a driver and minor offroad (hunting/farm type stuff) but I want the Bronco to be solid. Maybe down the road a complete ground up but for now it's one broken part at a time!
I might try to fab it back together or I found a replacement panel at LMC (part #8)(link below in case anyone needs)
https://www.lmctruck.com/1966-77-ford/fbr-1966-77-steel-interior-body-parts
I've updated photos below, I added a yellow line in one of the pics to show the windshield mount cowl lip that has rotted away/missing on mine in case someone down the road has similar issue. This was an odd one.
