Looking to get $1300 for the pair. Pulled from a 1979 Ford Bronco.
Dana 44: New upper and lower ball joints, rotors, Warn Premium hubs, wheel bearings and seals, 4.56 gears, install kit and Locrite.
Ford 9": New 4.56 gears, install kit, and Detroit locker. Axle has been cleaned and painted...has backing plates but u need hard lines, wheel cylinders, shoes, drums, and hardware kit.
Gears on both axles have been done professionally. Front axle needs assembly other then the gears. Front comes with caliper cores and needs hard lines, calipers and pads. I can finish assembly for the front if you like, just need a day or two with work being crazy. $1300 for the pair is shipped via Forward Air to any of the 48 continential states.
Brian
Brian
