That's an original Bronco manifold? Hmm, been awhile since I've seen one, but would have sworn it was a later piece like would have been from an Explorer.
Duals may or may not sound better. Depends on what you like. Sound is a very personal feeling.
Many think it's better and many don't think it matters.
Power, again, depends on how it's built and what components you use. You could get more power from a single if you're comparing a small dual to a large single. It's not just about flow always. Sometimes it's about "the tune".
If that's a stock EFI Explorer engine, you don't need maximum flow. You just need a properly sized system for your application. Bigger than stock is ok, but go too big and you'll end up with other issues.
I prefer a good breathing single nowadays.
I don't have a sound preference one way or the other. I don't need the flow of a well-designed dual system in a lower revving off-road/daily driver type truck engine (if you're planning on max hp at higher rpms all the time, go for it) and a single is WAY easier to route down the right side and out of the way of the fuel, brake and electrical sytem.
Yes, dual tips out the back still look cool. But I'm more than happy to lose the tip choices for a more convenient and better designed system overall.
Personal preference.
