2.5"/1" Leveling kit -Rear Install Options
jackwagon
First time post, I think. My first try didn't take. Anyway, I've researched a lot on here and can't find the answer.
I'm a proud new owner of a 72 LUBR. It came with a JBG 2.5" Deluxe leveling kit still in the box. This kit is only a 1" lift in the rear. I want to put a 31x10.5 tire on it eventually. The kit says it will only accommodate a 30x9.
So I'm considering - adding 1.5" block in the rear, or add a leaf(not sure what size) or 1" body lift, or some combo of body lift and SL.
The other question is that the kit came with shocks. If I raise the rear another 1.5" will they still work, or do need a new shock or adapter.
See my garage for pic.
SHX669
Well I'll answere one part of your question - I wouldn't put in an " add a leaf spring " unless you want to experience what it's like to ride in a " Buckboard Wagon".
bronconut73
1" body lift is a good idea anyway. These eb's somehow look more "right" with the 1" body lift. 2" appears to be a little too much for a lot of folks.
jmangi62
^^^^ Also if you want it to ride decent,do NOT install add a leafs or blocks,the only real way to do it right is to replace the stock springs with new leaf spring assemblies from one of the vendors here,they all have very nice parts for our early broncos. I run the Wild Horses 11 packs on my rig and love em.Absolutely nothing wrong with the 1" body lift either,I run the WH kit and it was one of the best mods I did to my rig. :cool:
jackwagon
jackwagon
The kit is new, but JBG won't give credit on a 2 year old kit someone else bought. (I can't say I blame them)
I guess the options would be try to sell the kit on craig's list or ebay or here, and buy another.
OR I use the kit and do an add a leaf. But all the add-a -leaf kits I find are 2.5" and up. I'm concerned the stance would be off.
Essentially I would be 2.5" lift in front, and 3.5-4" in the rear.
I guess I did find a 1.5" at SDTruck Springs - but very little info on it. - http://www.sdtrucksprings.com/index...cts_id=31458&gclid=CLjf543G1tICFZSEaQodg8MJBQ
Any thoughts?
Blue Bastard
Use what you have, order the 11 pack springs for the back and you ready to go.
While I'm in agreement with the others about the difference between an add-a-leaf and a new spring pack, I'm not sure you need any of that for a 30" tire. And even a 31" tire on the correct wheel could work for the most part.
I also agree about the Bilstein shocks. Tried to buy my own set yesterday but got caught up in talking to all the cool Bronco-folks out in the world!;)
Mondays during tax-return season are a bad time to be thinking of myself...
Anyway, in answer to your shock size question, each individual shock may vary depending on what the vendor uses, but the typical shock range is like this:
0-2 inches of suspension lift uses one size.
2.5-4 inches of lift uses longer shocks.
So your front shocks should work fine, but the rears could be too short for a 2.5" lift, if that's what you're thinking. I believe there are still some 1.5" leaf packs out there (Duff maybe?), but most of us have eliminated that choice and go straight for the 2.5" and up sizes.
I've used all three styles of lift over the years and have not had as many negatives as some, but I'll run down the pros and cons a little more. For starters though, an add-a-leaf or a 1" block do not necessarily make your rig unstable or unsafe. But like anything else, 99% of the truth to that statement lies with you, the driver. The rest of course, is parts and installation.
Blocks: inexpensive and add uncontrolled leverage that can lead to increased axle wrap. All leaf spring Broncos have axle wrap to a certain extent. You may be shocked if you look underneath one while someone is accelerating away. A block gives more leverage, but is not in itself unstable.
Add-a-leaves: Generally acknowledged to stiffen up the ride, because they are adding a leaf. It just follows. The thicker and shorter the leaf, the stiffer that effect is. Longer thinner leaves minimize the change, which is an inherent design characteristic of the modern 9, 10 and 11 leaf packs we all sell now.
But I will say that if your existing leaf pack is in dire and destitute shape already, the add-a-leaf might actually make your ride "better" after all. By "better" though, I mean it's still going to be stiffer, but it may reduce some of the perceived harshness by letting the leaf packs move easier over small bumps.
That was my personal experience with medium sized (shorter, but not thick) leaves.
New thick leaf packs: Disadvantages are only cost and slightly increased axle wrap. But the latter is not enough to overcome all the advantages, and even the first one (cost) is often softened by the benefits.
They ride better than any of the old ones ever did or could and still carry the weight and have safe handling characteristics. You can make softer leaves, but then you start to compromise the other aspects. They're also safer in at least one respect, and that's that most, if not all of them have the military double-wrapped front eye that keeps the spring contained and the vehicle off the ground if the main leaf ever breaks. Which, under extreme conditions they still can. Pretty extreme, but it's still possible.
Most of us don't have issues with axle wrap, but if you're heavy into off-roading, heavy in the right-foot department, or have big tires and lots of engine, there are traction aids/wrap reducers that can help there.
As you've seen from the other's comments, new springs have got it all going on.
Make no mistake though, the shocks play an absolutely vital and HUGE role here.
Lots of good ones out there, but the Bilstein 5100's have the whole bang-for-the-buck and ride quality thing dialed in to a top degree. Very nice stuff.
So, all that spewed out... What are your intentions with your Bronco? What do you want it to perform and look like? Who's driving it besides you, and how far do you want to go?
Oh, and welcome to classicbroncos too by the way!! Whereabouts in the world are you? Might be plenty of local members nearby where you can check out their EB's and see what they've done and what you like.
Good luck!
jackwagon
jackwagon
First off, thanks for all the feedback. I was afraid I might get the cold shoulder for being the idiot newbie. Thanks.
Paul to answer your questions, I'm in southwest Missouri. My plan for the truck is hunting vehicle, moderate trail riding, the occasional drive work, and the lake. Probably nothing longer than 2 hour road trips. But I've heard there are few Bronco events in my area.
Long term adding front discs, efi, maybe power steering, and of course some bodywork and paint. As you all know all that leads to other ideas and thoughts and extra cash.
That said , it sounds like most are recommending new rear leaf spring. Which will mean new rear shocks.
Any thoughts on what I might be able sell the 1" lift leaf and it shocks?
Also will a 2.5" spring need shims? Or is that one those "every bronco is different" items and wait and see?
haha! Yep, one of those "you might, then again you might not" kind of things.
In this case, I've been saying for quite awhile that with the 2.5 height, it's about 50/50.
When you get to 3.5 though, that ratio goes up to about 90/10 with more needing the shims.
So if you get a set of leaves, I would buy the shims too just to have on hand. If you're doing it on a weekend you won't have to wait. Worse yet, if you're having a shop do the work you won't need to either tie them up waiting, or go back later to have them installed.
It's not like the vehicles are not driveable mind you. It's just that you don't want to drive much on a vibrating driveshaft. The u-joints don't appreciate it much.
