1970excursion
- Joined
- Sep 16, 2010
- Messages
- 307
Bronco does not have a lot of getup and go from a stop but comes to life on highway.
no tags on axles so when I wanted to check what ratio I had, I jacked up one tire in rear, put tranny in neutral and spun the drive shaft and watched how many times the tire turned, and it was not even a 3 to 1 ratio. matched on the front, so without pulling the cover and counting teeth on ring gear I am stuck. Would it have come from the factor with a 2.94 gear ratio?
wierd. I will run up to speed and check my RPMS at 60 now that i have a tach installed. also guage reads 85 when gps says I am at 65, does this confirm the ratio or put it in the other direction?
33" tires and a C-4
33" tires and a C-4
