1buckeyefan1
- Sep 21, 2017
- 632
So i'm a little stumped on how to wire up my horn button. I'm using a Flaming River tilt column (1 wire plunger through canceling cam), painless harness w/ horn relay (pictured). I had an older Scott drake steering wheel + 2 terminal horn button that I'd like to use.
I have double terminals on the rear of the horn button. I believe this is to be used for non-relay horn setups (1 power, 1 ground.. that was attached to the wheel). Can I use this with my 1-wire relay setup? Based on the threads i've read, I simply need to ground out to activate the relay in order to activate my horn? However, I tried both terminals last night and couldn't get any honk-honk sounds?
