2000 explorer 5.0efi swap???
Rojo
I just bought a 1972 and I am new to the Bronco scene. I am thinking of installing a 2000 explorer 5.0efi serpentine setup hydroboost and 4r70w. Are there issues with the heads in this year that I need to be concerned with as far as headers go? Is this a good year motor to swap?? Any pointers greatly appreciated!! Thanks
crawler73
I know that year has the "P" heads so a lot of people use the Bronco Hut shorty headers.
'00 should be the P heads. Last non-P heads were early '97
P-heads have the funny plug angle that can be problematic in fitting headers.
surfer-b
You want hav any prob, the factory Explorer manifolds work perfect, no need for headers unless you just want them. Never seen a 96-01 5.0 explorer with a timing belt
mattyq17
I was wondering the same thing came across a 2000 explorer complete and running for $500 on Craigslist, says it won't pass smog because of computer error, don't know how many miles. I want to go 351 since I have no motor right now but could definitely use the tranny.
Rox Crusher
don't let the P heads scare you off, they are actually pretty good heads from performance perspective
they just require use of Bronco Hut headers due to the spark plug angle
R
Rojo
Ok thanks for the input. Now I just need to make a decision! Haha not easy
G's Baja Bronco
Sunny SO CAL
I read that somewhere, about the belt, I went with a 93 5.0 HO from a 92 t-bird and used gt40P heads with double springs over the low revving single wire explorer valve springs.
so have you seen a dual roller timing set, same as the HO's or single roller/nylon gears? just curious for future knowledge.
G
