this one?Look to be a delphi box....Borgeson remakes them which is to say they fit the stock pitman are and factor holes for the Bronco
I run one....no issues
Tim
That's the one I'm running. Not sure it's Xterra specific.....Think there were variations of the "Delphi" box.this one?
https://www.borgeson.com/P-S-Conversion-66-77-Ford-Bronco.html
looks a little different on the boreson web site? could be a newer version of the xterra one?
thank you for all the info. What year range titan for the rag joint?It is a Delphi box. None of them are an exact match. It is a very universal box, used in a lot of OEMs. There is a Jeep version (late 90's grand cherokee?) that is an inside the frame mount, but has the correct sector shaft. Mix that sector shaft with the Nissan box and you can use the stock Bronco pitman arm. Use the Nissan input shaft and a Mercury Villager steering shaft will fit perfect. That can be mated to a Nissan titan rag joint (half of one anyway) and that will mate to a factor Bronco power steering column.
And it is an '01½-'04.
Xterra and V6 Frontier (must be torsion bar suspension, not coil spring). The coil spring frames used a slightly different steering box.
Never on a Pathfinder (some claim to be, but it isn't true). Pathfinder went to rack and pinion in '96, long before Delphi supplied steering boxes.
agreed! most of my 67 build was from WH - and top notch service to boot...That's the one I'm running. Not sure it's Xterra specific.....Think there were variations of the "Delphi" box.
Bought mine off eBay years ago from a Borgeson reseller. Not sure what WH is selling but you know they sell quality.......
Tim
2004 to present. It is under the dash, not under the hood.thank you for all the info. What year range titan for the rag joint?
sweet2004 to present. It is under the dash, not under the hood.
I hope I remembered all that correctly, that was about 15 years ago.
the one on WH website seems to be itentical to the pic i posted and to the item descrition pics on Rock Auto. Do we know which one WH is selling?
https://www.rockauto.com/en/catalog/nissan,2001,xterra,3.3l+v6,1374588,steering,steering+gear,7416
https://www.wildhorses4x4.com/produ...ring_System_Deluxe/bronco_Power_Steering_Kits
those are not the manufactures of the OE boxes they are the companies the REMAN the OE boxes.On Rock Auto’s website, next to the part, click on “info” and the manufacturer is listed. This goes for everything that Rock Auto sells.
does the xterra box have to be from a V6 like the frontier?It is a Delphi box. None of them are an exact match. It is a very universal box, used in a lot of OEMs. There is a Jeep version (late 90's grand cherokee?) that is an inside the frame mount, but has the correct sector shaft. Mix that sector shaft with the Nissan box and you can use the stock Bronco pitman arm. Use the Nissan input shaft and a Mercury Villager steering shaft will fit perfect. That can be mated to a Nissan titan rag joint (half of one anyway) and that will mate to a factor Bronco power steering column.
