2023 Bronco Flat Towing
bronco t
San Diego CA
Looking for any advice or cautions on towing a 2023 Badlands Sasquatch. I had the RV dealer install an Airforce One brake system with TOAD charging, and diodes in the rear tail lights. We have towed the Bronco ~200 miles so far with no incident (yet). However after reading FB RV forums there are multiple claims that certain fuses need to be pulled, and batteries go dead if the TOAD is left plugged in to the RV over night. Thank you in advance!
ransil
I take mine out of tow mode when I stop over night and take it for a drive if possible, sometimes during a long lunch break.
I don't use a charge line or power from the bronco while towing , I use NSA ready brute tow bar which is an inertial brake system and wireless lights.
I have gotten a low battery message on the Ford app after towing for about 12-15 hours so that is why I added taking it for a drive.
Check the manual I for my 24 there was no mention of removing fuses , my 21 has a TSB for them before there was a software update for the ABS module, but I didn't removed fuses cause I was using a mechanical system.
I have towed about 10k miles on the 21 and 6k on the 24 so far.
