... well I'm going to say you should be able to find that on any corner.
Kind like your thinking too hard. .. But I'm on TEXAS not kalif.
OLDER STUFF nearly had 9 inches in them . & older small motor had 28 spline .. Now remember .. If you just put it into you 66 to feel it roll around the block. DON'T PUT IT INTO 4X4 .. .... SO YOU'VE BEEN WARNED ..
But when you do.
Go get into some really soft dirt or very loose gravel . Then put it into gear & locked up on your hubs . Let out slow on the gas .. If front & rear match nothing happens then they match gear ratios.
.... IF You get a lot of slipping or tires are chunking gravel .. Then your gears don't match.
... Some of the Mud trac guys put ..like 3:55s up front & 4:10's in the rear.
i could be backwards . & Remember they like to work on their rides.
... But most of the older 9 inch should be 28 or 31spline . If you can take an old axle with you stuff it into the punkin ..
& Remember sometimes the U-joint yoke is wrong.
