289 overheat
chileanbronco67
Hi! I have been searching a lot, but i can’t resolve my overheat but the courios think its only the cilinder 4 it turn the exhaust mainfold red the timing its 6 bt
And i have adjuste the valves.
I show you a pic that you can see crearly the problem
I hope its not a burned valve
72Sport
It is running lean. Since it is onlly one cylinder look for a leaky intake gasket.
Some have bought a can of starting fluid and sprayed it around the head gasket /intake gasket and see if rpms increase. Be careful. If you use too much you or you might have a fire or lose some eyebrows or worse. use it outside not in the garage or?
spap
Typically I don’t think ford water pumps flow equally with pass sides running hotter,
Def lean as said. Get an IR temp reader and see how much hotter it s running compared to the other side.
Bronco-Brian
Lake Oswego, OR
I've experienced #4 cylinder misfire due to PCV valve port on this runner when running after market aluminum intakes. Might want to check where the runner can pull bypassed air.
C
chileanbronco67
Yep its running lean i have made modificatons in my carburator and the red exhaust mainfold changed from one cilinder to other so i will test the carburator from my mustang thx for the answers
gr8scott
You should never connect a PCV valve to a single intake runner. It should be connected to a port that's common to all the cylinders, like the base of the carb.
I'm more curious on your valve adjustment. As these engines do not have adjustable valve train in stock form.
If you are suspecting a burned valve (and that could very well be) it's time for a compression test or better yet a leak down test.
bmc69
289s had adjustable rockers...I don't recall exactly what year they changed the stud design to make them bolt-down non-adjustable though.
nvrstuk
PNW
Definitely do NOT run it... remember what temp alum melts at!!?? You have got to be getting close to that with that shade of red on the cast iron exh manifold...
Since you said you had a different cyl running extremely hot when you rebuilt a carb, then it's a pretty good guess that it's your carb, not an intake leak and not your valve adj on that cyl.
Slap a carb on there that you KNOW works perfect. Go from there.
Good luck.
Rustytruck
if this 289 head came from an engine with a smog pump there may be an injection port on the firewall end of the head leaking air but you should hear that. Most of these old 289 engines had an exhaust crossover adapter plate under the carb with a hole that doesn't get covered by the gasket if you do not use the adapter with the proper gasket. so check for that. pop the top of the factory carb and check the jet sizes high altitude jets were pretty lean at #47 or so and at sea level were around #52. #4 runner is a long runner but a close shot to the PCV port on the bottom back of the carb make sure the PVC plumbing is not leaking and properly hooked up.
72Sport
Don't Run it as stated in the above post. Do you have the plate under the carb for the PVC hose to hook up to? Ford used them in a lot of the 70's vehicles. It is a cast aluminum plate with a port for the pcv hose to hook up and is mounted with the carb mounting bolts. They used them on both 2 and 4 barrel carbs. Looking at the intake I would guess that maybe you decided to do without it because of hood clearance. Take some pictures from both sides of the engine so we can see how things are plumbed.
I wouldn't worry about melting anything on the intake. The real problem is going to show up when driving under load and you overheat the piston in the rear cylinder, ruin the piston and score the cylinder wall or worse. I have a piston and block I can show you what happens when running lean. it isn't a Ford piston but it tells a story.
C
chileanbronco67
There are the pics
72Sport
There are the pics
I have a 66-83 Chilton manual. It shows the PCV valve mounted in the passenger side valve cover. The hose for the PCV valve is attached to the center of a spacer block, mounted beneath the carburetor. The carb has the another hose coming from the drivers side valve cover to the air cleaner. The CA stock system uses a smog pump and the big egr valve that goes under the carb. You have neither the smog pump nor all the parts to run it stock Ca. Send me you email address and I will make copies of the pages from the Chilton manual plus what ever I can find.
72Sport
I think this is the key to your problem.
My book shows the EGR cast iron valve under the carburetor. Finding a non-EGR carb and maybe a non EGR intake manifold may solve all your problems if that is what you have on your engine now.
The '67 may not have had an air pump, and no Broncos had EGR until '73, so he's probably ok in those regards.
Unless by "EGR" you are referring to the exhaust gas channels under the carb for heating?
The PCV can actually be in either valve cover, and in fact between '70 and '71 Ford did swap the valve to the driver's side and the vent hose went from the air cleaner to the passenger side instead.
The only external fitting on most of the early spacers was the PCV.
Most of them on early models did not even have any extra vacuum fitting that I remember. Newer ones did, but don't remember any of the old ones having anything but the PCV hose.
Speaking of those channels in the spacer, even the cast-iron ones would get chewed up over time by the exhaust gasses. The aluminum ones were the worst!
Lots of vacuum leaks caused by the deterioration, and quite a few more by mis-matched gaskets.
72Sport
The Thermactor system, with smog pump, was used on all 1967 with manual transmissions and all Calif models sold in CA and most 75-83 Models according to Chiltons manual 1966-83 for what ever it is worth.
