3 Speed Manual Steering Column Disassembly
Okie69
I’ve opened up a can of worms and need some assistance getting the lid back on. It’s a ‘69 with a stock 3 speed on the column. I took out the bushings for the shift linkage to replace them and it looks like I have to remove the arms completely to install the new bushings and I figure there’s probably more in there that I can replace to fix my linkage getting stuck at stop lights issue.
I’ve searched and haven’t been able to find a good how to for disassembly and reassembly of the column. I’m learning as I go and by no means a mechanic. Does anyone know of a resource that can baby step me through this process, and maybe even show what parts to look closely at to see if they need replacing?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Exploded diagram
jcm1967
I am rebuilding mine right now. What I found was the tabs on the shift tube had broken loose. I had to do some careful welding and grinding to reattach them. Fixing those along with a new shift collar and shims/bearings hopefully will have mine repaired. I have it fully disassembled right now so I could pm some pics if you need them. I can’t post yet.
Jeff
bamabaja
The Shoals
Check CB archive articles. I found those articles invaluable.
