74 stock EB, 302 3 speed RAT trans finally on the road and sorting out the bugs. All new, clutch, u-joints, seals, axle bearings, fluids, etc. Truck drives well EXCEPT when in 3rd gear and NOT under a load. Quiet during acceleration or deceleration. I get a noise that I THINK is the trans. Sounds to me like a worn thrust washer or something. A rattle/whine. When I had the rear diff out changing the fluid I could see that the truck must have sat with moisture. Portions of the ring n pinion have some rust/pitting but it only makes the noise in 3rd gear. Checked thru the posts but couldn't find anything close to the same. Thoughts anyone? FYI, when the trans was out and I had the top cover off to clean it out, it looked pretty clean except for the normal type of sludge found in old gear oil. No filings and the gears looked good to my eye. Trans seems to shift pretty well also. Thanks.
