3-Speed Top Speed?
joshm28
Jasper, AL
I run mine down the interstate at 70-75 frequently. With 31's, 3.50 gears and the original 3 speed I turn less than 3 grand at 75.
stock1970
Olathe, Kansas
yesterday i had to drive to the airport to pick up my step son and i ran between 80 and 90 all the way, .. but mom, everyone else was doing it to.. but i was the only 1970 vehicle in the pack.. lol.. so i guess i set a new record for me. as stated before my tires are from 1992.. they run smooth and show no dry rot but you never know.. maybe one of these days i will take it out for a tripple digit run .. i was only 10 away but let us know what your fix is..
AWS
ST LOUIS
When I get calls about someone purchasing a old tractor, excavator, backhoe or truck, first thing I tell everyone when they complain about no power...If it's been sitting for awhile check for wasp/mouse/bird nests in the intake, then check mechanical linkage. After that look at fuel delivery.
Steve
67primer
67primer
Dallas
Thanks for all the help guys! I look forward to future threads...Lord knows I got plenty of topics.
302fix
If it's all stock then your points were probably dragging you down/need adjusting.
Get a pertronix upgrade then drive it. Power problems are usually in the ignition system.
DonaldDouchebag
Steve
A plugged exhaust can do it as well. I was on a roadtrip in a VW Golf a few years back that suddenly became very sluggish. I tore open the muffler with a screwdriver and pair of pliers and found that the tube inside had rusted and fallen causing the exhaust gas to get trapped inside the muffler. I happily drove on with the back of the muffler missing and had no further trouble.
Muddn7
alamogordo, nm
I wouldn't dig into the rear yet. This post has good help! I would (if I were in your boots) buy a cheap tach, install, test drive, document, post results! If your timing is off, it will make you think your motor is screaming for help at 55 and 2200 rpm.... Get a tach, set the timing at 10btc (v-8 ford standard) and go from there!
TonyC
Belmont, MA
My 1966 6cyl. had the same issue. It was fixed by the adjusting the throttle linkage and rebuilding the carburator. Sounds like a fuel delivery issue. Check the fuel pump as well for any leaks, etc.
deltarat
Drew,Ms
My bronco once all of a sudden lost it's power. I wouldn't do but 45 on the highway. It took the ford place a week to find out the muffler had collapsed on the inside. It look good on the outside, but would not let it breathe.
67primer
67primer
Dallas
I just tore into the breaks this weekend so it will be a few days before I can test. I will post when I can get it on the road.
br0nc0xrapt0r
Loves pickles
I am afraid I won't be able to tell you what speed your capable of until I see pictures of this thing sorry it's an important step.
rubywoofs
Southlake
I'm curious, too. I got my 74 (302, 3 on the tree, 4.11s, 29 inch tires) about three weeks ago. First time on the highway this weekend and felt like I was tached out at 60 or so. It runs pretty well, but not a lot of power - no way I could imagine getting it to 75 on power or tach. Hmm, check the ignition and fuel supply, huh?
...I got my 74 (302, 3 on the tree, 4.11s, 29 inch tires) about three weeks ago. First time on the highway this weekend and felt like I was tached out at 60 or so.
As I think someone mentioned, you might be pretty surprised at what sounds like high rpm when, in fact, you're not that revved up after all. A lot depends on the type and condition of the exhaust also.
Mine came with discrete duals, using old crusty glasspacks, 30" tires and 4.11's, so not too far from yours in gearing. When I first started driving it, I already knew pretty much what engines would typically sound like at a certain rpm and was sure it was revving close to it's limit. And that was when the speed limit was 55 and we rarely cruised for long above about 60! The occasional burst to 70 or 75 made me sure it was about to come apart at the seams.
It wasn't.
It just turned out that, in my case, it was mostly the exhaust, along with a little bit of ticking in the lifters. Starting at about 2500 rpm I was already thinking I was getting up there. By 3500 I thought I had reached the limit for sure. When I finally bought a tachometer and found out just what the rpms really were, I had to laugh and started to relax.
Then, a couple of years later, when I replaced the exhaust with dual generic turbo mufflers, all of a sudden the whole sound changed and going 70 wasn't quite the chore it had been.
What type of exhaust are you's guys running?
Generically speaking, I thought that the quieter the exhaust, the higher the engine speed sounded. It's more a flow than a sound though I guess, since my glasspacks were anything but quiet. But they were definitely not flowing well, since I didn't have much power either (sound familiar?) and had difficulty climbing those mountain roads on the way to the Sierra trails.
New exhaust, even a quiet one, fixed that good.
broncnaz
Check and decode your VIN tag it will tell you what axle ratio you should have. But as some of the others have said more than likely its low gearing and small tires coupled with a older engine that your not used to so the RPM's may seem high. But the power loss could be due to tuning issues that need to be addressed.
Even if you had 4.56 gears and 29 in. tires the engine should be turning just under 3000 RPM. 289's love to rev up. And you should still be in the engines powerband.
my 71 with a 302 3 sp, 4.11's and 31's runs great at 55 mpg but I havent really taken it faster than that. But I have no doubts it will easily go 65+. I just dont drive it that much.
rubywoofs
Southlake
My exhaust is stock, so that could be it. Maybe I'm thrown off by the sound like you said and just babying my ride too much. The exhaust is on my list, so . . .
Anyway, just don't want it to be the gears and wheels because mine is a luber and I don't want to start changing gears, cutting fenders, etc.
crews44
Mullica Hill, NJ
x3. Had a 86 Silverado that the cat converters (not an issue with the bronco w/ not cats) went to crap and would barely pull any hills. Not good in Upstate NY as it is all hills. Check that exhaust as well as what everyone else is mentioning. Good Luck.
Of course, there is that other aspect to be noted as well. These things were sold as true "Utility" vehicles to a lot of people for sure. Before the "Sport" part was added and they became SUV's instead. In your year they even had a 4.56 ratio option, so you can imagine what that would be like on the highway!
Then again, using it on the ranch with a PTO winch and bed-mounted auger for digging post-holes, and never seeing the high side of 40 miles an hour going to town, the low gears didn't cause anybody any undue stress. And even if they got it on the freeway for awhile, they would have been one of those guys that many people look say mean things about as they cruise along near the shoulder at 47 miles an hour to get to the next parcel to fix that dang hole in the fence where those durn pesky whippersnappers slid through 'cause they were taking ol' Dead Man's Curve to fast again!
Dang city-folk. Always in a hurry...
Yours would have been right at home sitting along side the old service station most of the year, then pushing snow (with the optional snow plow of course) in some ski-resort town all winter!
Hmmm, where are you located by the way? If in Colorado, Utah, Wyoming or Montana, we might be on to something!
