3 speed Transmission differences?
Tram
Hey guys-
Back story:
I've got 2 Broncos..
A "middle of restoration" 1966 with 302, 3 speed and Dana 20 out of a '74.. Good running gear.
A mud toy, 1974 with a 351W, 3 speed and Dana 20.. No clue of the donor vehicle. 351w block date code indicates a Dec of 74 build..
The '74 is seeing some engine issues, which I'm looking at sorting out. I've also got what I suspect to be a warped flywheel. Shutters down low from a dead stop..
Anyway, I'm seriously considering swapping the two running gears. Pulling the engine, tranny and transfer case and just swapping..
If I get the 351W running right, I'm also considering just swapping trannies, which brings us to this post..
Tranny in the '66..
Tranny in '74..
The 3 speeds vary visually just a bit. Most notably, the transmission in the '74 is missing the drain plug where the '66 transmission has one.
I'm wondering if they're compatible.
If I pull the transmission out of the '66, should it bolt right up to the 351W?
TIA
broncodriver99
Glen Allen, VA
Most of the 3 speeds are pretty much the same. There were a couple of different ratios. As long as they are both V8 transmissions they should be the same length and compatible. The drain plug omission is something that Ford did somewhere in the late 60's. You just remove the bottom adapter housing bolt to drain it.
Tram
Tram
I didn't see any tags, but I didn't look too hard..
I'll see if I can round up that info..
broncnaz
Unless the transmission is giving you problems leave it. While there really are no big differances in bronco trannys unless it was a 6cyl tranny which is slightly weaker and has a slightly lower first gear. There is no reason to pull the tranny to fix a chattering clutch. Just resurface the flywheel and install a new clutch.
Tram
Tram
Well, I'm getting some bucking/shuddering coming into 1st, but last night while reading, I read about axle wrap, so I'm wondering if that's it.
Yeah, usually not the transmission itself. Not that there couldn't someday be something to do that, but I've never heard of it originating from the trans.
Axle-wrap, bad driveline angles, bad u-joints, bad clutch (the most common cause), loose or worn out motor and trans mounts, etc.
All the stuff mentioned in your other thread.
Unfortunately, given all the possibilities, you really can't ignore any of them at first. Luckily though, checking most of them does not involve much in the way of tearing down or heavy lifting.
Tram
Tram
Anyone know of a good write-up for swapping the clutch/flywheel?
I've got a spare 3 speed that works great I may swap.
broncnaz
As Dirtdont said. Your bucking may be due to your worn clutch/ Flywheel. or worn/loose motor/transmission mounts. Of course large tires and high axle gearing can be a root cause of it as well.
Tram
Tram
Yeh, I need to look at those.. The engine may be in trouble, if it is, it'll all come out and be swapped for a spare 302, 3 speed and Dana 20.
