3 speed transmission with electric switch/sender?
serial car restorer
Western Oregon
I've spent a few hours under my '69 refresh project, installing new tanks, fuel lines and an electric selector valve. And while I was looking at stuff underneath I found something I wasn't expecting—a single wire with a very factory-looking connector on the side of the 3 speed transmission.
After disconnecting the wire, I found the other end was connected to nothing, terminating in a crimp-on female spade. The connection on the transmission has a round rubber-like pad with a single threaded stud in the center. It is on the left side of the transmission, just forward of where the external shift arms go into the 'box.
Knowing almost nothing about this rig's history, I really can't say that this is definitely the original transmission from 1969. But ANY electrical connection on an early Bronco transmission seems odd to me. It's only a single wire, so it's not a backup light switch. Did later Broncos have a top gear switch like some cars to mess with the timing for emissions?
Or is there something else I haven't thought of?
serial car restorer
serial car restorer
Western Oregon
Looks like some years did have a transmission switch to do something to the timing, so that has to be what this is. I found this reference in a wiring diagram for 1972. Does anyone know when this started? What years had these? I suspect this transmission might not be the original 1969 'box.
EDIT - Looks like '72-73 only. So apparently mine does not have the original transmission in it now.
Correct. 72 and 73 only. Part of the “ambient switch“ system.
Worked along with a sensor mounted in the driver’s door jam/A – pillar.
I’m not sure if cars got the same transmission, though. If the transmission is coming out, verify what the first gear ratio is.
Or if you’ve been driving it, is it pretty easy to start off in first gear, or does it seem a little sluggish?
Reason I ask is that some transmissions were “close ratio“ so to speak and had a taller first gear. I would expect that in a passenger car rather than a truck.
I swapped one into my 71 while I was working on the original transmission, and while it was quite the pig in first gear, even in four wheel, low range, I sure did enjoy the narrow spread between first and second.
